120V Solar Installation
solar
#1
Hello,
I have a different type of Solar System. My solar inverter is only 120V, therefore there is only One Black wire (HOT) and one white wire (Neutral) Coming from my solar Inverter.
In this case I would only be able to hook up one clamp on the black wire, the second clamp would have nothing to connect to. Will this work, or will Sense not be able to calibrate because one clamp isn’t connected.
#2
@madfrench469, yes, you should be able to use Sense with your solar system. Just reach out to our support team (https://help.sense.com/hc/en-us/requests/new) and they help get that set up for you (a couple changes need to be made from our end).
