Billing Cycle Support in Trending
#1
I haven’t found a way to do this, so I’m posting under Product Wishlist. If someone knows of a way to do this today, please share.
Trends would be more relevant if there was the ability to show a “Month” based on your specific billing cycle which may or may not align with a calendar month.
#2
I asked for a similar thing too … linking just to keep them together.
#3
I totally agree. My goal of owning Sense is to reconcile my electric bill and understand why it is so how compared to my neighbors. This is a critical feature for me.
#4
+1 - great idea
#5
I would love to see this feature too.
ComEd in Chicago is also installing smart meters, I would now be extremely curious.
#6
I have two complete months logged now, December and January, my power company actually bills on the month cycle, so Sense works. One slight discrepancy and maybe the law of averages will work out. December showed 1687 billed and 1770 Sensed, delta of +83 to Sense, January was 1837 billed and 1666 Sensed, a delta of -171 to Sense. that’s about a ten percent error rate from Jan, will wait to see what February surprises will bring.
The watt meter runs close but it is forever changing, and within 10% is not bad. Has anyone else noticed anything or taken a summary measurement to compare to the power company. I have real billing numbers, not estimated BTW, due to the smart meter. thanks all for the bandwidth. curious what everyone else has.
#7
I think 10% is way out of the norm - something’s up with either your install (eg correct wiring) or your device (eg software bug).
After a lot of effort on my part, I was able to figure out that our nighttime consumption was almost perfect; our daytime production (solar) and consumption is about 3-4% underreporting, both due to an error in the solar production calculation by Sense. These are based on twice daily meter readings, pre-sunrise, post-sunset.
Before the voltage correction in December, I was 10% off across the board - and I was ready to send mine back. I can guess my numbers closer than 10%.
Even with the lower error rate, I’m still torn. I think getting these numbers right is perhaps the most important thing Sense needs to be doing right, given device discovery is a slow and imperfect process I’d at least like some useful information.
edit and the reason I’m torn is because it’s obvious the correlation problems are diverse and widespread, meaning this isn’t a simple fix involving some software correction you can push to every user, and surely wasn’t entirely corrected with the “voltage fix” in December. What that means is that it’ll be incredibly difficult to fix for everyone, and from the looks of it, promises to be fixed for no one. I mean, I’ve had my device since November and have been vocal about the errors from the start. Very frustrating.
#8
I agree that each users situation is different. I think the fix is to allow us to apply a “correction factor” to match the meter reading.
In a similar vain, during nighttime, we should be able to “trim” each leg of the Solar CTs to a 0W reading. In my case, my night time readings are -6W and -36W on each leg. The reason the 2nd leg is -36W and not -6W, is that I have some always on network equipment in the solar sub-panel. Being able to trim this out would be nice.
I don’t want to just do a Solar re-calibrate which is hit or miss, just give us the ability to manually apply correction factors, maybe via a restricted service menu or something for “expects only”.
#9
+1 for billing cycle comparison
#10
setting start of billing month would be good feature to have. Please implement
#11
This feature is on it’s way and should be introduced in the near future!
