Dual CT clamps for parallel feed
It would be neat to see a dual CT clamp setup to where each one of the ct clamps had two clips per wire so a parallel feed could be monitored. I recently purchased the sense and I have been having trouble with the calibration (stuck at 70%). I suspect my house is parallel at two 100 amp panels that feed into one single service feed (I’m not sure though). I have two mains and each one of them has a red and black going into it. I think if there was a way to have the CT cables have two heads on each wire (like a Y clamp setup per panel-both Y’s would feed into the same Sense port). Would that work?
Just as a side note: I have touched base with tech support. They are looking into it :slight_smile:
