Electric Blanket question
#1
I have had my sense for close to a year now and it has discovered many items. It has yet to discover my electric blankets and they are on every nite for quite a while. I am just wondering why? I don’t think their energy consumption is so low that they would not be picked up. Any theories?
Thanks! Jeff
#2
A good point. They are typically 200W devices that I’d expect would cycle like many heaters controller by a thermostat. So I’d not expect Sense to identify one as an electric blanket, but as Heat X, as electrically it would be the same as, say, a 200W warming tray.
Do you have any unnamed Heat devices in your device list?
Worth looking through any of those.
Let us know what you find
#3
I have had sense for approximately 8 months. It has found 23 devices in that time.Electric blankets are on every single night with my wife’s being on for several hours. I have checked and I have no unlabeled devices except for a light source sense found yesterday and I have not pinpointed yet. I don’t know why it has not discovered the electric blankets
#4
If you go to Settings > My Home > Sense Monitor and scroll down to Device Detection, do you have anything listed there under Currently Learning and Up Next?
There might be something there that fits.
#5
It is currently learning a motor and the AC and the possibly up next is the oven.
#6
@js1, it may come down to the need for detection algorithm improvements around that type of heat. We do have some work scheduled in that regard, which may help. I wish I had a better answer for you.
#7
After just a few days, the first two devices found were an unclassified “Heat 1” device and a “Microwave”.
The “Microwave” was indeed correct – it will be interesting to see what happens after using the “Convection” part of that Microwave/Convection Oven a few times . (I did add Manufacturer & Model)
The “Heat 1” device was an electric blanket (from the times it was on vs. off), and so I renamed it. So that was a quick “ID”.
#8
I have several electric blankets. It does not find any of them even though they are on all night. What I have found, at least for the ones I have (king and queen each with two separate sides) is that the blanket cycles regularly, like every second or so on and off. I’ll get a pict and update later if I can.
#9
Yes, the electric blanket cycles on / off relatively quickly. We only have one … I wonder, @DavidSense007, if you turn them all on at nearly the same time … or not.
I’d venture that they might be more clearly identified if one were turned on for a while, then, say 30 minutes later, another was turned on, etc.
I say that because the refrigerator and freezer were “identified” at nearly the same time (within an hour or so on the same day). Even though they probably have similar on/off “signatures”, the fact that they are on/off at different, but sometimes overlapping, intervals, probably helped the neural network to identify them as two different entities. I suspect the electric blankets have similar “signatures”; by having them “run” at different ‘starting’ times, that should help them to be identified as different “instances” of similar “heat” devices.
#10
Good question, the answer is No, they are not turned on at the same time, generally several hours apart
#11
One of the blankets goes on around 8pm and is on for a few hours. The other goes on around 10:30 pm and is on until around 2am so the are on at separate times. I just think it is very strange that they have not been discovered yet.
#12
Oh. An FYI on the “Electric Blanket” found: It is actually a dual-control Queen-size blanket. One side is on at a low setting (1 of 10) for only a brief time to ‘pre-warm’ that side of the bed. The other side starts out at a higher setting (e.g. 4-8 of 10) for a brief while, then remains on all night at a low setting of 1-2 (of 10). The “pre-warm” “time-of-day-turned-on” is usually about the same for both sides (typically within 10s of seconds). From looking at the ‘power meter’ when it is on (low setting, one side only), it is a pretty distinctive, regular on-off cycling pattern … which undoubtably contributed to its early detection.
