How many installs, approximately?
I’ll have to look at mine, I wonder if M is a model iteration. Someone mentioned a flashing light on theirs recently, which I don’t believe mine has.
I understand and share the concern, but more relevant than the number of devices installed is the actual number of devices identified. After 3 weeks, Sense has identified 15 devices in my home, including a number of the “biggies” including the heat pump, water heater, clothes dryer and fridge. It has not found the electric range (which we do not use much) or the Clipper Creek electric car charger (which they may not have seen before?).
Has Sense not found the significant energy users in your home?
After 8 months my Sense has found the garage door opener, the water heater, the dryer, device and motor unknown. Not so good at this location! The solar appears spot on but took weeks to get right and the Sense staff never shared how they solved the problem or even what the problem was. Appears to me their automation still requires a heavy dose of human.
Sense has not found the following at my home (among others) after 5 months or so:
None of the PCs of which there are three; 1 of two color laser printers; no lighting within or outside home nor shop; 1500w in-wall electric heater in tack room; 3hp well pump12 gpm; 7.5hp air compressor; 5hp shop central dust collection; 3 strip electrical resistance heating backup to 5ton heat pump (has found heat pump itself, but not the variable speed fan); freezer; neither 60+ inch plasma tvs; Yamaha 200w sound bar; microwave; convection oven; kitchen cooking fan; and several tools and devices which are only operated episodically as I work through a wood working project.
The devices Sense has found include:
Bosch refrigerator; Liebherr refrigerator; Bosch clothes dryer; Carrier heat pump; coffee maker; garage and barn overhead doors;irrigation pump; 1 laser printer; Miele range and warming oven; 80 gal water heater; and an as yet unidentified Heat5.
