Running multiple wires thru the current clamps
#1
Hello there,
Little bit of an unusual setup: I have an outdoor panel with the connection form PG&E, where the meter is connected to the breaker box via bus bars, not cables (thus cannot put the current clamps around them). Can’t put the clamps before the meter, because that’s PG&E.s
The external panel feeds some devices like my well pump, EV charger, and outdoor power, and then there’s the feed into the house. I can put the current clamps onto the feed into the house, and the sense can detect those devices, but not the breakers on the outside panel. In looking at the picture, the breaker above the mains is the well. I think I might be able to route those wires along with the house mains thru the current clamps (so there would be the house gauge wire along with the 12 gauge ware thru each clamp.
Will that work ok in terms of being able to detect the well pump?
#2
Had somewhat the same situation - bus bars feeding the main panel. My electrician cracked open the PG&E meter side to clamp around the cables before the buses, then routed the clamp leads through a small opening between the sides, to the Sense on the breaker side of the dual box.
#3
Hello there,
Interesting. My electrician was not enthused about doing that, as he indicated that you’d have to be careful not to short the meter out (unless you broke the PG&E tag), and PG&E would be very unhappy if they found it…
#4
Most of the Techs have seen hundreds of Tags cut off. If you explain it to them they will most likely understand. Show them your Sense app and hell, he might want to buy one too. Their geeks too ya know. :sunglasses:
