@ThomasBrock Have you worked with Support on this at all? I’d reach out to them and see if there is anything obvious blocking detection for you.
But yes, EVs are an elephant in a room – absolutely. They’re major consumers and they often stick out visually. However, they’re not the only device like that. There are other 220V devices that can fit the wattage profile, like pumps, central ACs, and big heat sources. Thus, it’s not as simple as merely filtering out anything below a wattage threshold. We wish it were that easy. We would love if the solution was so simple. Alas, it’s not, but we’re working very hard to get better (and more!) EV models online.
I highly recommend tuning into the webcast tomorrow as this subject will likely be touched upon by our VP of Tech. Year End Webcast - 12/21/2018 3-4pm ET
