Disappointed in device discovery
The only way devices get removed is if (1) they have not been renamed since Sense found them or (2) they have been renamed but have been ‘marked as a Guess’. Otherwise, for a device to be removed, it has to be done manually on our side, which is not done without informing you. If you’re seeing devices get removed outside of those criteria, you should let Support know.
See Device Detection Update: Device Updates!
