How do I change my CT sensors to Solar?
If I go to Dedicated circuit monitoring, there is no delete or Off mode that I can find? Says to contact Support?
Would like to just turn off the CT Sensors for now…(electrician working on the panel)…then switch on the Solar mode for them? How do I do this?
I would assume when your ready to use the CTs as solar you would just open the app/ settings/ monitor/ solar then click enable and then it will run thru the solar calibration.
