Hi,
What kind of data does Sense retrieve from HS110? Just the instantaneous power consumption or voltage/current info?
Hi,
Not sure of the full range of data/status that the HS110 can produce. But based on a few Netshark scans I think Sense only asks for power info via this request packet broadcast on the subnet to port 9999:
{“system”:{“get_sysinfo”:null},“emeter”:
{“get_realtime”:null}}
A better view on what the HS110/HS300 can respond to. Again, I believe that Sense only uses a single realtime command.
