What would you want to come out of the solar information portion ? Sense essentially has enough geo information to run a PVWatt simulation to predict hourly and daily solar output from your location.
The challenge is as @ixu described - weather, aging/dust and shading will all cause the results to diverge from your real production. Even the NREL simulator itself applies “statistical weather” to the results so when aggregated over months or a year, the results are accurate, but not so much on an hourly or daily basis. And if you want to overlay simulated solar production vs. Sense, there are pretty straightforward ways to compare Sense export data against PVWatts already.
Again, the real question is what you would want to see come out ?
