Long term data wrong for first 10 minutes of hour
Since March 24th, the values shown for energy usage for the historical data are wrong for the first 10 minutes of the hour. Here are two screenshots from the app at 11:01 and 11:11:
Also visible if you graph the values in HomeAssistant:
I confirmed this issue with the team - thanks for the report! They’re on it.
This might be the same thing, but what Home Assistant’s integration has been pulling for awhile has sags regularly. I’m seeing it at 10 minutes after the hour until 20 minutes after
Same problem for me, bad data if you look in the first 10 min of any hour.
