Using Shelly EM Gen3 CT Clamps with SenseLink to monitor circuits that Sense has a hard time discovering.
Each Shelly EM Gen3 can monitor TWO circuits with two separate CT clamps.
Let me start of my stating that I am not an expert but was just tinkering around to be able to monitor more circuits in my all electric house–in particular oven, cooktop, dryer and mini split inverter.
I used a Raspberry Pi 3B and installed SenseLink via Docker and MQTT broker. Before installing the Shelly EM Gen3 into my circuit breaker box, I set it up outside and labeled the units. I read many topics to try to figure out which parameters to use but, in the end it was trial and error. I hope this helps anyone who is clueless like me be able to tackle this project.
Key steps:
Shelly EM Gen3: Installed in breaker box with a separate 15A double pole breaker (to monitor 240V). Each CT clamps to each circuit you want to monitor. Labeling them will help identify correct circuits.
Enable MQTT on Shelly device (via app), Server use your Pi IP, MQTT Prefix: unique name like “shelly-unit1” “shelly-unit2” (remember each unit can monitor 2 circuits)
When installing onto the circuit you want to monitor, it does not matter which directions. If it is negative, you can always use the Shelly app to change.
Senselink yaml was a challenge for me…this is what I did for it to work
Sorry the spacing is not correct for copy and paste into your own senselink.yaml
sources:
- mqtt:
host: #use your Pi static IP
port: 1883 #must us this port number
username: " " #empty if no auth
password: “ “ #empty if no auth
plugs:
* Oven:
alias: "Oven" #name that shows up in Sense
mac: "e4:b0:63:d4:a4:01" #make up any mac but different for each
power_topic: "shelly-unit1/status/em1:0" #0 or 1 at the end specify which clamp
power_topic_keypath: act_power #act_power reports the watts
apower multiplier: 1 #not sure if this is needed
* Cooktop:
alias: "Cooktop"
mac: "e4:b0:63:d4:a4:02"
power_topic: "shelly-unit1/status/em1:1"
* Dryer:
alias: "Dryer"
mac: "e4:b0:63:d4:4c:03"
power_topic: "shelly-unit2/status/em1:0"
* MiniSpit:
alias: "MiniSplit"
mac: "e4:b0:63:d4:4c:04"
power_topic: "shelly-unit2/status/em1:1"
destinations:
sense:
username: #your sense account
password: #your sense password
