Is Sense any better at tracking induction cookers lately?
Assuming the energy generation, be it local or grid, is at least renewable, if not solar (i.e. disregarding issues of Utility power being fossil-based), beyond load shifting and cooking when the sun is shining, are there any reasonable methods to go all-electric? Cookers with super-capacitors or powered via batteries? Is anybody periodically running their induction cooker from a Powerwall? Do the embodied energy metrics of Li-ion batteries even lend themselves to such uses?
Which leads to my main question: Can Sense be used to control electrical use where, for example, you might use an induction cooker (or other device) and specifically not want that to run off of a battery and degrade it? Is anybody using IFTTT or other methods to do this for induction cookers or other devices?
There is undeniable logic to cooking when the sun is blazing and then freezing your food at night and in the dark days of winter, using the freezer as a battery!
For reference, I went here some years ago. Solar + Diesel, oh dear:
Consider the “water heater” on a small scale though as a kettle. A small “instantaneous water heater”. In order to justify the insulation required to make a “keep warm”, or near-boiling, tank (in this case a small one) more efficient it needs to be “cheaper” than electrical/heat generation.
Physics dictates that heat loss is harder to prevent the smaller the volume. The bigger the tank, the more efficient it can be. On a practical level, at some point (small volume) you’re fighting an uphill battle against heat loss and “instant” heat starts to win. Sufficient insulation becomes too expensive.
An idealized fridge/freezer should definitely be dumping heat into water and heating it (at least in summer): a fridge should dispense hot water! That pretty much embodies the difficulty with the calculus. Manufacturers end up making things that sell that are certainly not ideal.
Kettle calibration: On the smallest of scales I’ve found that Sense has helped me to innately calibrate my ability to fill the kettle to just the right amount without wasting any excess hot water, and most importantly without fiddling with, say, filling a single cup and then pouring it into the kettle to heat. Efficient laziness.
I converted my 1907 home to all electric. When I called the gas company to ask them to remove the meter and the line to my house they had me sign a waiver acknowledging that it would cost a future owner more money to bring gas back to the house. I told them that is precisely the point!
