@kevin1 ,
I was finally able to install Home Assistant as a VM in ESXi. I will say it was a real challenge… Until I spotted haos_ova-7.2.ova on the net. I have no idea how I found it (Had too many windows open to trace my steps. TG I saved a copy, because I am going to have to nuke it and start over.in my attempts to do what you did (Create a graph with overlays) Somehow I managed to duplicate everything, then I broke it by eliminating everything. Although, I must agree with you that HA is very helpful.
If you could be so kind, Could you please guide me how to edit “Overview” that is the one view I had that is now corrupt.I have searched the web for help, but the examples there assume an older version that has other functions like editor. I see how to make other overview pages; however everything there is again single icons.History graphs are probably the closest I have so far but I noticed that new sense detections are nowhere to be found. Correct me, if i am wrong, did you earlier say that you could export the data from HA to a file that could be manipulated using external graphing tools?
