Note: The Sense Home Energy Monitor should be installed by an electrician or qualified professional, and should be installed in compliance with all applicable local codes.
Installing Sense is very straightforward and generally takes a licensed electrician less than half an hour to complete. For more details, please consult the Sense Installation Guide and the Sense Installation Video below.
If you need to install your Sense monitor outside of your electrical panel, please refer to our external monitor installation instructions.
If you have a recessed electrical panel that is flush mounted with your wall, see our recessed panel installation instructions.
Unsure of whether Sense is compatible with your electrical panel configuration? Take a look at our compatibility guidelines.
