I found that my 1800 btu Gree minisplit draws a constant 75 watts in use or not. Since I only use this unit for air conditioning I flipped off the breaker until next cooling season. Sense has not detected the mini split but it’s current is monitored by an independent c/t (part of my demand load controller).
dwleckie
3
Related topics
| Topic | Replies | Views | Activity | |
| Mitsubishi Ductless mini split heat pump issue | 25 | 1386 | January 6, 2024 | |
| How well does sense detect various Heat Pumps? | 100 | 9900 | February 28, 2023 | |
| Mitsubishi Ductless Mini split winter losses found | 15 | 2096 | March 31, 2021 | |
| AC detected but not showing up in the bubbles | 19 | 2015 | July 2, 2021 | |
| Device found, recognizing and then dropping out | 27 | 1626 | August 9, 2020 |
