"Other" vs. "Always On"
I have had my sense for nearly 2 years now. It has found many things but not all.
My “other” continues to be fairly consistent.
  1. What is other and how does it differ from Always on
  2. With app in hand I began unplugging things. What made Other noticeably drop was: Can Lamps in ceiling and Ceiling fans
So why after 2 years when these are used daily can’t it detect them? I the live view there is a drop or spike when I turn these on and off. So there should be some sort of pattern I would think.
Thoughts?
Regarding my can lamps, I found another post that said Sense can;t detect LED.
I’m using all LED in cans:
https://www.satco.com/s9410.html
I know sense is detecting something as I see a spike when i turn on and off.
Ceiling fans are basic electric motors and I would think be detectable
Good questions.
First off, Always On is the near-lowest power usage in your house over the last 48 hours on a rolling basis. You have to think about that as the usage in your house that is Always On across every device, including the devices that Sense detects. Sense looks for on/off power for a detected device, but has no way of directly measuring the Always On usage (with smart plug devices, Sense does give you Always On). The detailed Always On calculation is described here:
Other, is the Total Usage minus all the detected device on at a moment in time, including minus Always On.
Other should drop when you unplug/turn off things that Sense has not yet detected and should increase when those devices are plugged back in or turned on. But I have found it is far more useful to look at the Power Meter, especially in the phone/table app, for two reasons: 1) the Power Meter gives more details on the on/off waveforms and 2) Sense also gives hints about the transitions that it “hears” - you’ll see a power number / tag show up when it spots something of interest. This helps you know if there’s a chance Sense will detect something - first, it has to “hear it”. Example of tags in the Power Meter below - they are only there for that Power Meter session.
Kevin, very well articulated - Thanks
So here is a screen shot of the power meter. Ignore the +38W
When I cut off the can lamps (4 of them) I saw an -54w dip and +60 when i turned it back on.
Ceiling fan was a drop of 13W and plus 14W
So its clearly detecting something. Why can’t it identify those?
P.s. upon writing this I cant find the attach
Some folks have reported “Sensing” LED’s, particularly the larger array ones. LED’s, like so many energy efficient devices, apparently get lost in the overall noise in the home.
Depending on your device, attach is the little basket with an outgoing (up) arrow icon. On my phone, it’s below the text entry box. On bigger screens and web, it’s in the toolbar above the box. You can go back to the post without the attachment and use the pencil icon to edit/update your post.
COOL… Thanks File uploaded
So Sense is “hearing” those transitions, but hearing isn’t enough. It has to hear enough repetitions that are similar, under a wide variety of conditions, and yet detect that that set of ons and offs are distinct. I think the big issue in many homes is that there are a wide swath of 10-100W transitions that are not super distinct, mostly coming from electronic devices (yes, LED lighting is an electronic device). Electronics hide many of the distinguishing physics features that differentiate incandescent lights from heaters from AC motors. BTW - most ceiling fans today use electronically controlled DC motors, so that makes them fall into the “few distinguishing features” category vs. AC motors.
Thanks… Interesting
Since you seem to know alot (compliment) another question
Should I get a smart plug for both my entertainment center and computer (both btw are plugged into a power adapter/monitor first)
I would recommend that. I have plugged most of my electronics into either a power strip or UPS connected to a smart plug (HS110 or KP115) or used an HS300 (integrated monitoring power strip). In most of my cases, it really hasn’t helped to use the HS300.
Gotcha ill google those models
Did you see the part that both are going through a power unit first (entertainment center uses a panamax power management) computer to a UPS. Will that effect a smart plug?
A UPS shouldn’t affect the monitoring capabilities of those smart plugs - they just monitor the energy flowing through them and send the data to the Sense monitor. But the placement of the smart plug with respect to the UPS will make a difference in what you see. Before, will give you power used by the UPS plus the devices on the UPS, aligned with the house usage. Depending on the UPS type, this will add battery charging, active management of house supply, and/or the energy used for double conversion to your total, making it much more unlikely that Sense detects any devices on the UPS. If you put the smart plug after your UPS, you won’t see the UPS usage in the totals, and if/when it does kick in you will see power coming out of the battery to feed your devices, which is not coming from the grid. After placement, won’t help detection either, though you will get a more accurate view of just the energy your AV or computer devices are using. Before is the better choice in my mind.
WOW thanks Kevin
For the entertainment center I would assume before the panomax power management
Thanks any suggestions on which ones to get. I want good quality but being unemployed cant spend alot.
Btw stupid question but will nest now discover this devices and thus reduce “always on” and “other”. If so how will it show up on Sense - what kind of device (which I know I can change).
Looks like the Kasa-115 would be good for me - they are compatible with sense as I read. I would get 2 of them - entertainment and office
When you add the smart plugs, Sense will create a new smart plug device for each of them. Just like any other device, bubbles will appear for them and their usage totals will be removed from Other. The total Always On won’t shrink, but the Always On for each smart plug will be broken out in the Always On “device”. You’ll also be able to set a standby level for each smart plug device so that device can be in On, Off or Standby states. Actual measurements from the smart plugs bring added functionality-
Not many “Sense compatible” devices out there, but many of us have had good luck with the KASA devices (previously HS110, now KP115, and the HS300 for multiple plugs), both available at various prices. I’ve seen as low as $10 at NewEgg and it seems to run $23 elsewhere, so this can get expensive. Making Sense actually work can be very costly.
@kevin1 That will work for me. I’m only going for 2 devices - TV/Entertainment and Computer. So when it finds them I can easily label/tag them in Sense
:slight_smile:
I overloaded on HS110s over the last couple years as they went on sale. I’m only down to a few hundred watts of unknown loads. Hue integration is nice as well but way more expensive…
I looked into Hue, but as far as I can tell it doesn’t monitor power consumption. So I didn’t get any Hue. Did I miss something?
