If you truly have “a 208V” system, your townhouse is fed by 2 phases (and neutral) of a 3 phase supply which is typical for larger buildings, This is different than the typical residential split phase supply. Sense can work on a 2 of 3 phases supply, but you do need to be aware of differences.
ps: I’m wondering where both the conduits that contain mains thick black white and red wires go. One probably goes to the meter. The other ….
