Stages of Device Detection
Sense engineers and data scientists continue to work diligently to improve device detection. For many years, the Sense Home app could only show real-time usage for devices it detected on its own—by isolating each device’s electrical signature from everything else happening in your home. As many of you know, this process can be fast for some devices… and frustratingly slow for others.
Why? It comes down to how a device uses electricity along with the complexity of your home’s electrical activity, how often a device runs, and how similar it looks to others.
But things are changing.
A Smarter Way to Detect Devices
Starting last year, we began showing historical usage estimates for devices you tell us about—even before we can fully detect them in real time. Along with this shift, we introduced a device survey during setup. If you haven’t filled it out yet, we recommend doing so.
And now, there’s a new Add Device button at the bottom of your Devices list, which lets you identify eligible devices in your home. Use it any time to tell us about more devices in your home. Once added, you’ll start receiving usage estimates—even while Sense is still learning to identify the device in real time.
–Users who have not completed the survey but who are eligible for it will continue to see the survey prompt, and will not see the Add Device option. This eliminates ambiguity when completing the survey, and reduces the risk of duplicate device entries being created.
–If you’ve had Sense so long the survey isn’t available, you now have the Add Device button to add eligible devices.
–Not all devices are eligible. If your device is not listed, continue to wait for Sense to learn it in real time.
This all means your Devices list may now show a mix of:
  • Devices in inventory
  • Devices with real-time detection
  • Devices with estimated usage from historical data and perhaps limited usage tracking
NOTE: The new Add Device feature is currently only available on the Sense Home Energy Monitor. Since the product paths for Sense and Wiser officially split in May 2024, any new features or updates to the Wiser app are now managed by the Schneider Electric/Wiser team.
The Four Stages of Detection
Here’s how Sense tracks and displays the progress of learning each device:
Stage 1: Inventory
You’ve identified the device to us, but it’s still grayed out. That means we haven’t collected enough data yet.
Stage 2: Identified
The icon turns blue and we begin showing estimated usage based on historical data.
Stage 3: Tracking
Sense is confident enough to begin reporting actual usage in your home.
Stage 4: Real Time
The device is now fully detected in real time, allowing for detailed tracking across the app.
Not every device will move through all four stages—some may skip directly from Inventory to Real Time detection or skip an intermediate stage, depending on what Sense can learn.
Note: If you use smart plugs or other integrated monitoring devices to report information on a particular device, you are isolating that device from this device detection process. If a device is already partially or fully detected and you then use DCM or a smartplug to also monitor the device, make sure you go to the Devices tab where the device is being monitored by DCM/Smart Plug and click What’s Connected to This? then select the natively detected devices that apply. Otherwise, you will risk Sense counting both data points and that will likely lead to inaccurate readings.
What This Means for You
With more ways to track your devices and smarter detection algorithms behind the scenes, Sense now delivers energy insights in more ways than ever. You’ll get actionable info sooner—even while full detection is still in progress.
Have feedback or questions? Let us know. Your insights help make Sense smarter for everyone.
Thanks for the update, but I checked both my laptop and my phone. Neither one has an “Add Device” button on the Devices List. I have Version 1.46.90-3dbe2521-release. Is there another update that needs to be installed to get the ability to add devices? If so, how to I get the update?
Hi,
Thanks so much for your question—and are you part of the Wiser community?
The new Add Device feature is currently only available on the Sense Home Energy Monitor. Since the product paths for Sense and Wiser officially split in May 2024, Sense continues to support all core features that were in place before the transition. Any new features or updates to the Wiser app are now managed by the Schneider Electric/Wiser team.
Thanks for the heads up—I’ll revise my original post to make that clearer for others as well.
Best,
Deanne
I was originally part of the Wiser community. It moved to Schneider about a year ago. My app says Wiser but when you go to setting its says Schneider.
Yes Wiser is part of Schneider.
Okay. I’m I missing something. Why don’t I have the Add Device button?
Just to clarify—while the Sense app and the Wiser app (from Schneider Electric) once shared the same foundation, they are now separate.
The new Add Device button is only available in the Sense app. Sense no longer provides updates to the Wiser app, although we do continue to support all core features that were in place as of May 2024, when Sense and Schneider formally split.
Thanks for your question, and I hope this helps!
I may install the Sense app again. I may get better results. Thanks for the information.
I have multiple Kasa/TP-Link smart plugs and power strips monitoring multiple loads throughout the house, mainly because Sense wasn’t detecting many things in the house.
Should I remove all of my smart plugs, and replace my three TP-Link /kasa HS300 power strips with ‘dumb’ power strips to see if Sense can discovery things now?
I added the Sense monitor in May 2024. It has yet to detect major devices that I have added - dishwasher, electric dryer, oven, washer, and a instant water heater. The only devices it has detected is A/C, refrigerator and a condensate pump. Is this normal? Had hoped for better detection after a year.
@uconnjhd , so they are all still just at Stage 1 per the @deeeharper’s description ? I ask because there are specific descriptions of each stage. Best to speak in terms of those well-defined stages for best answers.
yes - dishwasher, electric dryer, oven, washer, and an instant water heater are all at Stage 1.
The A/C, refrigerator and a condensate pump are Stage 4.
Hi,
If you are having good luck with device detection on your smart plugs, I would not change this. As smart plugs directly monitor your energy usage, it is by default the most accurate way to do this. If you remove your smart plugs and put your devices on a non-energy monitoring power strip, you could add them as mentioned, but it is not likely the result will be better than what you are getting with your smart plugs now. You will also have to wait for Sense to detect your devices, which could take some time.
This depends on the home and brand/model of device and not just the device itself.
For example, as your refrigerator is able to be detected—and many people’s—mine has remained in stage 3 and never advanced to four. My fridge already monitors energy, so it feels even weirder that I can’t see it in Sense. When I lived at my previous home and had a much more standard and basic fridge, Sense detected it pretty quickly. This was before the multi-stage detection.
My dishwasher has never advanced beyond step one.
We have done some specific work on electric dryers, so while it’s far from a guarantee, ideally something should be detected eventually, even if it only stays in stage two or three. Device detection may also be based on the frequency you use it, even if it’s been over a year.
At my previous home I had an instant water heater in my old home, and it never was detected either.
Therefore, it’s not out of the ordinary, though we are working to improve detection.
Hi,
I’d be happy to clarify your question:
Schneider/Wiser monitors will not be eligible for these features as the code split happened before these updates were deployed. Conversely, if Schneider updates or changes their app or adds new features, the Sense “orange box” monitor will not receive those updates.
If you are using a “green box” Schneider Electric (SE) monitor, you will no longer be able to use the Sense app with it. This is due to the separation between the two companies.
I know this may not be the most desirable answer and I apologize. However, Schneider is working on new developments, so I would recommend staying tuned here: https://www.se.com/
If you need to reach out to them for any questions, you can contact Schneider support here: https://www.se.com/us/en/work/support/
Thanks again!
Thanks for the information. Now I know why I couldn’t install the Sense app and have it work. It kept referring me to the Schneider app. Hopefully the updates will come soon.
Will more items be added to the “add device” list?
I have an oldschool resistive space heater that comes on at least once a day (sometimes twice) and well over a year later it still hasn’t been detected, which is baffling to me as a non-electronic resistive heater would seem to have a pretty solid signature. Anyhow, I’d like to give it a shot via the “add device” option, but I don’t see anything at all for space heater.
I think there’s a bug in the iOS app (version 2025.5-bfe229ece build 4654) with the Add Device button/window. Once I open that window up, depending on where in the window I decide to scroll the view, the button that’s under my finger will get selected and it will add a new device for that item. I didn’t even have to click Add, it just closes the window as soon as it’s done scrolling, then adds the new device (ie, Fridge 3). It’s completely repeatable behavior.
Not sure what’s going on with it, but def a bug @JamesDrew
Hi, You are correct. This is a bug for iOS, and it’s something we discussed last week and are working on.
I’ll make a note to update this when I get more information.
With that said, there are ways to not select an item even after you pushed it. It’s a little hard to describe, but basically, when you use your first finger (thumb presumably) to select the device, you can use a finger on your other hand to move the screen away from the item, which should deselect it. The main way to not select the item is to make sure that when you raise your finger off the screen, you are not touching that device.
Also, if you do select a device you do not mean to and it goes into your inventory, just delete it. Do this by opening the “Devices” tab, selecting the device > gear symbol > Manage > Delete Device.
Granted, I am well aware this is not how the menu screen should work and it’s still a bug, but I just want to help in the meantime.
The short answer is yes, but I cannot say just what or when. I recommend you check back periodically, and I’ll ask about the space heater you mention to see if it’s something people are working on just now (and will add to this if I find out anything). Thanks!
