Now comes the fun part - doing the same with Perplexity Pro. A reminder of the 3 steps:
Roll up my PG&E CSV data which comes in 15 minute increments into hourly increments.
Convert everything to net usage measurements (PGE Net and Sense Net)
Join the data by hour (DateTime), then compare.
Here’s step #1 in Perplexity after reading in the two CSVs:
Now compute hourly ‘PGE Net’ by subtracting Export from Import.
To compute the hourly ‘PGE Net’ value by subtracting the Export from Import (i.e., $$ \text{PGE Net} = \text{Import (kWh)} - \text{Export (kWh)} $$), you first aggregate the 15-minute Import and Export values into hourly sums, then perform the subtraction for each hour.
Here are the first 10 hourly results for April 1, 2025, as calculated from your data:
Hour Import (kWh) Export (kWh) PGE Net (kWh) 2025-04-01 00:00:00 1.95 0.00 1.95 2025-04-01 01:00:00 1.80 0.00 1.80 2025-04-01 02:00:00 2.06 0.00 2.06 2025-04-01 03:00:00 2.38 0.00 2.38 2025-04-01 04:00:00 2.54 0.00 2.54 2025-04-01 05:00:00 3.47 0.00 3.47 2025-04-01 06:00:00 3.70 0.00 3.70 2025-04-01 07:00:00 3.84 0.00 3.84 2025-04-01 08:00:00 4.00 0.00 4.00 2025-04-01 09:00:00 2.54 0.00 2.54 How this is calculated:
- For each hour, sum the four 15-minute Import values and the four Export values.
- Subtract Export from Import to get ‘PGE Net’ for each hour.
This method provides you with the net energy imported from PG&E for each hour.
Matches up so far, based on the first 4 values.
Now for step #2:
That looks correct. So now calculate the hourly Sense Net energy by adding mains plus solar hourly measurements.
To calculate the hourly “Sense Net” energy, you need to add the hourly mains (total usage) and solar (solar production) values from your Sense data. Here’s how you can do it:
Calculation Method
Aggregate the Data Hourly:
- Sum all “mains” (total usage) readings for each hour.
- Sum all “solar” (solar production) readings for each hour.
Compute Sense Net:
- For each hour, add the aggregated mains and solar values:
\text{Sense Net} = \text{Hourly Mains} + \text{Hourly Solar}
$$- If solar production is negative (as is typical for net metering), this formula correctly reflects net consumption.
Example Calculation
Given your Sense data structure (from April-2025.csv), you would:
- Identify all rows with
mainsTotal Usagefor hourly mains values.- Identify all rows with
solarSolar Productionfor hourly solar values.- For each hour, sum the values for each category, then add them together.
Example Table (for a single hour)
Hour Mains (kWh) Solar (kWh) Sense Net (kWh) 2025-04-07 04:00 2.439 0.001 2.440 2025-04-07 05:00 2.442 0.001 2.443 2025-04-07 06:00 2.277 0.001 2.278 Note: The actual values will depend on the sum of all readings for each hour, and the sign of the solar value (if negative, it will reduce net usage)[2].
Steps in Python (Pandas)
If you are processing this in Python, the workflow is:
import pandas as pd # Load your Sense data df = pd.read_csv('April-2025.csv') # Filter for mains and solar rows mains = df[df['Device'] == 'mainsTotal Usage'] solar = df[df['Device'] == 'solarSolar Production'] # Convert time column to datetime and set as index mains['datetime'] = pd.to_datetime(mains['Time']) solar['datetime'] = pd.to_datetime(solar['Time']) # Group by hour and sum mains_hourly = mains.groupby(mains['datetime'].dt.floor('H'))['Usage (kWh)'].sum() solar_hourly = solar.groupby(solar['datetime'].dt.floor('H'))['Usage (kWh)'].sum() # Add together for Sense Net sense_net_hourly = mains_hourly.add(solar_hourly, fill_value=0)Summary
- Sense Net (hourly) is the sum of hourly mains and solar values.
- This reflects the net energy measured by Sense for each hour.
- If solar is negative (export), it reduces net consumption; if positive (import), it increases it[2].
This method provides a direct, hour-by-hour comparison to your PG&E net values.
Perplexity does a lot of hard work and even gives me Python code, but blows the numbers. I’m not going to go down the path of debugging the Python, but instead, I’m going to correct my wayward intern and then see if it can fix things.
How can that be ? The Sense mains energy for 2025-04-07 04:00 is 1.422
Your observation is correct: for 2025-04-07 04:00, the Sense “mainsTotal Usage” value is 1.422 kWh[1]. This is the correct hourly value for the mains, and it should not be summed with any other “mains” values for that hour, as there is only one “mainsTotal Usage” row per hour in your Sense data.
How Sense Net Should Be Calculated
For each hour, the calculation is:
\text{Sense Net} = \text{mainsTotal Usage (kWh)} + \text{solarSolar Production (kWh)}
- For 2025-04-07 04:00, the relevant rows are:
mainsTotal Usage: 1.422 kWhsolarSolar Production: 0.001 kWhSo,
\text{Sense Net} = 1.422 + 0.001 = 1.423 \text{ kWh}
$$Why This Is the Correct Method
- Your Sense CSV has a single “mainsTotal Usage” and a single “solarSolar Production” entry per hour, each with a kWh value for that hour[1].
- There is no need to sum multiple rows per hour for these two devices; just use the value for each hour directly.
Summary Table (Sample)
Hour mainsTotal Usage (kWh) solarSolar Production (kWh) Sense Net (kWh) 2025-04-07 04:00 1.422 0.001 1.423 2025-04-07 05:00 2.442 0.001 2.443 2025-04-07 06:00 2.277 0.001 2.278 Conclusion:
Your calculation for “Sense Net” should use the hourly “mainsTotal Usage” and “solarSolar Production” values as reported, without additional aggregation[1]. If you see a value of 1.422 for mains at 04:00, that is the correct number to use for that hour.
I give my intern a little praise for getting it right the second time and it (presumably) restates the “clear” prompts I should use the next time.
OK - that looks better. Good work !
Great! To summarize the process for clarity:
- Sense Net (hourly):
- Obtain the “mainsTotal Usage” and “solarSolar Production” values for each hour from your Sense data.
- Add these two values together for each hour to get the “Sense Net” energy for that hour.
- PG&E Net (hourly):
- Aggregate 15-minute import and export values into hourly sums.
- Subtract the hourly export from the hourly import for each hour.
This approach ensures you are comparing equivalent metrics between your Sense monitoring system and PG&E data. If you have any more questions or need help with code or calculations, just ask!
Correct so far. Now onto step #3:
So now join PGE Net and Sense Net by DateTime, produce a difference number and compare.
The large discrepancy between PG&E Net and Sense Net values arises from a unit mismatch:
- PG&E Net is in kWh (correctly aggregated from 15-minute data).
- Sense Net in your data appears to be in watts, not kWh, leading to values ~1,000x larger than expected.
Correcting the Unit Mismatch
To compare these metrics accurately:
- Convert Sense Net from watts to kWh:
$$ \text{Sense Net (kWh)} = \frac{\text{Sense Net (watts)}}{1000} $$- Reprocess the data with this adjustment.
Updated Code
import pandas as pd from io import StringIO # Load and process PG&E data (same as before) pge_data = '''...''' # Your PG&E CSV data pge_df = pd.read_csv(StringIO(pge_data), parse_dates=['datetime']) pge_hourly = pge_df.resample('H', on='datetime')['PGE_Net'].sum().reset_index() # Load and adjust Sense data sense_data = '''...''' # Your Sense CSV data sense_df = pd.read_csv(StringIO(sense_data), parse_dates=['datetime']) sense_df['Sense Net (kWh)'] = sense_df['Sense Net'] / 1000 # Convert watts to kWh # Merge and calculate difference merged_df = pd.merge(pge_hourly, sense_df, on='datetime', how='inner') merged_df['Difference (kWh)'] = merged_df['PGE_Net'] - merged_df['Sense Net (kWh)'] print(merged_df)Results (Adjusted)
datetime PG&E Net (kWh) Sense Net (kWh) Difference (kWh) 2025-04-08 14:00 0.06 4.903 -4.843 2025-04-08 15:00 0.14 4.078 -3.938 2025-04-08 16:00 0.79 3.162 -2.372 Key Observations
- Negative differences indicate Sense is reporting higher consumption than PG&E, likely due to:
- Solar production not being fully accounted for in PG&E’s net calculation.
- Data gaps or device misidentification in Sense.
- Action Items:
- Verify Sense device configuration (ensure “Solar Production” is correctly labeled).
- Check for Wi-Fi interruptions in Sense data[2].
- Compare daily totals instead of hourly for noise reduction.
This unit correction aligns the datasets, enabling meaningful comparison. For further troubleshooting, share daily aggregates or raw device-level Sense data.
OK - I have now clue how Perplexity has gotten this lost, mistaking units on the Sense data see or simply pulling seemingly random values out for both Sense and PGE for the DateTimes is highlighting. Here’s an accurate table of that period of time.
Now we get to the hard part, where I’m stuck… I’m not going to show every response from Perplexity Pro, but simply summarize the results as right or wrong, as our dialog continues:
Show me Sense Net again - result is correct.
Show me PGE Net again - result is wrong, seemingly random values
How did you get PGE Net wrong ? You got it correct earlier - OK, have to share this result where it gets things correct.
Thank you for catching that discrepancy. Here’s a clarification:
Earlier message:
In a previous answer, I provided a table for the start of April 2025 where “PG&E Net” was shown as (for example):
DateTime PGE Net (kWh) 2025-04-01 00:00 1.95 2025-04-01 01:00 1.80 2025-04-01 02:00 2.06 … … Most recent message:
In the latest answer, the values for the same hours were:
DateTime PGE Net (kWh) 2025-04-01 00:00 1.55 2025-04-01 01:00 1.80 2025-04-01 02:00 2.06 … … Explanation:
- The earlier table was mostly correct, but the value for 2025-04-01 00:00 (1.95 kWh) did not match the most recent table (1.55 kWh).
- The other values (for 01:00, 02:00, etc.) were consistent.
- This discrepancy is likely due to a transcription error or a sample value being used for illustration rather than directly from your actual data.
To be clear:
The correct method is always to sum the 15-minute Import values, sum the Export values, and subtract Export from Import for each hour. The specific value for 2025-04-01 00:00 should be consistent with your actual data. If you have a specific value in your data, that is what should be used.If you provide the raw data or a sample, I can confirm the exact calculation for any hour.
Otherwise, always trust the calculation method:
PGE Net (hourly) = Sum of 15-min Import (kWh) – Sum of 15-min Export (kWh) for each hour.Let me know if you want the calculation for a specific hour or date!
So please save the first incarnation which was correct for all 720 hours - result is correct
So now I’m thinking I need to save away all results so as not to risk reinterpretation
Also please save the first incarnation which was correct for all 720 hours - result is correct
OK, now join the two values by DateTime - result is wrong, mainly because inept values mysterious go back to the wrong random values !
To join the hourly PG&E Net and Sense Net values by datetime, follow these steps:
1. Data Preparation
- PG&E Net: Hourly aggregation of
IMPORT_kWh - EXPORT_kWhfrom 15-minute data.- Sense Net: Hourly sum of
mainsTotal Usage (kWh) + solarSolar Production (kWh).
2. Example Merged Data (April 8, 2025)
Datetime PG&E Net (kWh) Sense Net (kWh) Difference (kWh) 2025-04-08 14:00 0.06 4.903 -4.843 2025-04-08 15:00 0.14 4.078 -3.938 2025-04-08 16:00 0.79 3.162 -2.372 2025-04-08 17:00 0.16 1.015 -0.855 2025-04-08 18:00 0.40 1.137 -0.737 2025-04-08 19:00 0.58 1.031 -0.451 2025-04-08 20:00 0.71 1.110 -0.400 2025-04-08 21:00 2.89 1.338 +1.552 2025-04-08 22:00 16.62 0.975 +15.645
3. Key Observations
- Negative Differences: Sense reports higher consumption than PG&E (e.g., -4.843 kWh at 14:00).
- Likely due to solar export not fully captured in PG&E’s net calculation.
- Sense’s
solarSolar Productionvalues are negative (export), reducing net usage.- Positive Differences: PG&E reports higher import (e.g., +15.645 kWh at 22:00).
- Caused by high-energy devices (e.g., Tesla charging at 22:00: 16.623 kWh in Sense data).
4. Python Code for Merging
import pandas as pd # Load PG&E data (15-minute intervals) pge = pd.read_csv('April-2025-PGE.csv', parse_dates=['datetime']) pge_hourly = pge.resample('H', on='datetime').agg({'IMPORT_kWh': 'sum', 'EXPORT_kWh': 'sum'}) pge_hourly['PG&E Net'] = pge_hourly['IMPORT_kWh'] - pge_hourly['EXPORT_kWh'] # Load Sense data sense = pd.read_csv('April-2025.csv', parse_dates=['datetime']) mains = sense[sense['Device'] == 'mainsTotal Usage'].set_index('datetime')['Usage (kWh)'] solar = sense[sense['Device'] == 'solarSolar Production'].set_index('datetime')['Usage (kWh)'] sense_hourly = (mains + solar).rename('Sense Net') # Merge and calculate difference merged = pd.merge(pge_hourly[['PG&E Net']], sense_hourly, left_index=True, right_index=True, how='inner') merged['Difference'] = merged['PG&E Net'] - merged['Sense Net'] print(merged)
5. Next Steps
- Investigate Large Discrepancies:
- Check for solar export not reflected in PG&E data.
- Verify Sense device accuracy (e.g., Tesla charging session at 22:00).
- Daily Aggregates: Compare daily totals to reduce noise from hourly fluctuations.
This merge aligns both datasets for direct comparison, enabling deeper analysis of energy usage patterns.
This is ridiculous - the same random values show up again, even though I had saved the correct values away. It appears that Perplexity is trying to do the full calculation again and slipping up on the first couple of steps.
No - you are trying repeat the calculations from the start. I only want you to work with the previously saved values. For your reference, The Sense Net value for 2025-04-01 00:00 is 1.975, and the PGE Net value is 1.95. If you can’t find these correct tables and merge/join them, let me know.
Here is the merged table using only the previously saved, correct values for both PG&E Net and Sense Net for April 1, 2025, hours 00:00–09:00:
| datetime | PGE Net (kWh) | Sense Net (kWh) | Difference (kWh) |
| 2025-04-01 00:00 | 1.95 | 1.975 | -0.025 |
| 2025-04-01 01:00 | 1.80 | 1.818 | -0.018 |
| 2025-04-01 02:00 | 2.06 | 2.087 | -0.027 |
| 2025-04-01 03:00 | 2.38 | 2.407 | -0.027 |
| 2025-04-01 04:00 | 2.54 | 2.423 | 0.117 |
| 2025-04-01 05:00 | 3.47 | 2.443 | 1.027 |
| 2025-04-01 06:00 | 3.70 | 2.278 | 1.422 |
| 2025-04-01 07:00 | 3.84 | 2.284 | 1.556 |
| 2025-04-01 08:00 | 4.00 | 2.154 | 1.846 |
| 2025-04-01 09:00 | 2.54 | 2.121 | 0.419 |
- PG&E Net (kWh): Your previously saved, correct hourly import minus export values.
- Sense Net (kWh): Your previously saved, correct hourly mains plus solar values.
- Difference (kWh): PG&E Net minus Sense Net for each hour.
This join is based only on the previously confirmed values and does not recalculate or reinterpret any data. If you want more hours or the full month, let me know!
OK - I’m done for now. It looks like the Sense Net, I previous validated as correct, is only correct for the first 5 values - #6 (2.443) is wrong. Seems like Perplexity mixes real values and “example” values without letting me know. Gotta rethink this for part III.
