14 days ago I was notified of some lights. One room has CFL bulbs. I confirmed it was that room. As of today those lights showed up in my bubble as the same room. However, the lights were in a different room. I guess this can be expected since it also has CFL lights?
On a related note, I was wondering if LEDs are harder to detect? Seems like my halogen under cabinet lights were recently detected
Not a biggie since I am looking forward to identifying the bigger energy consumers.
I’ve shared this previously, but it’s worth mentioning again that anything under 40W is very hard to identify in real-time. CFL bulbs usually use more than this (I’ve seen a few from 50W-65W), so when I see a detection of a light I often take it as an opportunity to hunt down and replace a bulb with a more energy efficient one.
I also have Hue bulbs, which I can integrate with Sense to detect through the app.
If you’re looking for an example of LED consumption, here’s an example @kevin1 shared in the Community Device Library of an LED floodlight (which is significantly higher wattage than a typical LED bulb) that uses ~40W.
My hue bulbs in my living room use about 7-10W a bulb
