Difference In Daily Total Usage
I did a post on how to check correlation and isolate discrepancies here:
A few possible causes for discrepancies:
  1. Sense CT not completely closed - Sense number lower than utility
  2. Data loss from Sense - Sense number lower than utility
  3. Utility data issues - Utility number could be lower or higher
Possible sources for your discrepancy depend a fair amount on your utility and how they collect readings and provide to you. If you have a smart meter, as it appears you do since you can get daily data, then most likely your meter sends readings every 15min or hour. But not all those readings always make it through to the utility thanks to wireless communications issues. If data is missing, the utility will substitute estimated reads for actual reads.
