This will all be automatic through our Ecobee thermostats. Based on what I have heard, the AC will attempt to overcool just before 3PM to get a running start when there is plenty of solar, then back off from 5PM to 6PM.
Here is Phoenix, it would be futile to precool slightly just before 3:00 PM on days like today (forecast high 114 F or 45.6 C). Running my two heat pumps flat-out might maintain indoor temperature, but that’s about it. I’ve turned Eco+ off on my Ecobee thermostats, and instead use home automation software. Sense measures my power use and solar panel output.
A number of folks here pre-cool significantly early in the day (prior to the summer peak-rate period of 2:00-8:00 PM), and allow temperatures indoors to drift up. Today my routine set my two HP’s to 69 F at 8:00 AM. By 2:00 PM, I expect indoor temperature to be around 74 F. (To get lower I’d need to start pre-cooling much earlier.)
After 2:00 I use home automation software to change Ecobee setpoints depending on net power use for the home. You are welcome to check out this long post.
The Eco+ approach seems to work OK for Bay Area (CA) weather and matches the PG&E TOU pricing schedule. I generally only need to have AC on when my upstairs is occupied from mid-aft through about 8PM. Our current warm spell ranges from 59 at night to 85 daytime. Only two caveats:
Trying to avoid natural gas, so we use electric floor heaters some mornings, but I do some automation to turn off floor heating if temp prediction for the coming day is 70 degrees or warmer and sunny, so I can keep the thermal mass of limestone cold.
The Eco+ connection to the utility PG&E prevents me from using OhmConnect - PG&E only supports a single demand response program at a time.
