Sense Integrations are a particularly useful way to pull-in power usage data from devices that don’t fit the main Sense AI detection model and to pull data from Sense to run home automations. Here are some of the most important things to know about the integrations.
There are more than you might realize. There are currently seven measurement-type integrations supported in the Sense code base, though a couple more entered beta and were retired due to various technical difficulties. I consider Sense DCM (dedicated current monitoring) as an integration, even though it operates entirely within the same Sense monitor. By “measurement-type”, I mean integrations that help Sense measure and identify power usage of devices and either expand the range of devices Sense can monitor or provide an auxiliary route for Sense to pick up on/off detections. There are also three more that help out with home automation, though one is user-developed (Home Assistant integration). The table below covers all the publicly discussed integrations, including one that never passed beta, plus highlights possible caveats.
Each integration speaks has own “language” or protocol - to talk and listen to smart devices. Until very recently, there haven’t been any widely adopted standards for communicating power usage information between smart devices. So Sense has had to develop separate bodies of code for each integration. The chart below highlights one major difference in communications - some integrations communicate directly between the Sense monitor and the smart device via your home network (intra LAN) without going out to the cloud. A couple more need to go out to the cloud to pull data from another cloud-based monitoring system. But even between the Intra LAN devices, the protocol is different. Even though it is not a true standard, people have reverse engineered the TP-Link Kasa protocol and have used it to provide “measurements” back to Sense from many other sources, including the Home Assistant home automation hub. This is very useful for code-savvy users that want to add more smart devices to Sense’s repertoire of integrations.
Even within measurement-type integrations some provide different data to Sense than others - Several report direct power measurements back to Sense as one would expect. The Hue hub doesn’t measure the the power, but uses the on/off and brightness settings for each bulb to provide Sense with estimated power usage. The NDI integration simply listens to the network and tells the monitor when it sees a specific smart device turning on or off so Sense can match up an on/off transition to the device. And the Ecobee Historic integration provides Sense with what your HVAC devices were doing over previous intervals of time.
Different integrations have different update intervals - You can see the update intervals for some when you watch the Device Power Meter for that device. You’ll actually see waveforms get updated, perhaps with a couple second lag for the ones that rely on the Cloud as the data source). In most cases the update happens every 1/2 second to 2 seconds. NDI doesn’t really fit the sampling model - it’s always “listening”. The Ecobee integration only lets Sense pull data every 5 minutes even though the Ecobee data is updated every 5 seconds. That means that the Ecobee isn’t useful for realtime detection, but is very useful to Sense for verifying and improving their HVAC models, especially for customers that have the Ecobee integration turned on.
Teach me something - I use most of these integrations, except I don’t have any NDI devices that shows up in my device list, and don’t have any WeMo plugs. If you have either of those, feel free to contact or add more in the thread below.
| Type & Integration Name | Smart Device | Provided Data | Update Interval | Data Source |
| Measurement-Type Integrations | ||||
| NDI (Network Device Identification) | Smart TVs | On/Off & Device Info | NA | Intra LAN |
| Sense DCM | Flex Sensor | Power | 1/2 - 1 sec | Intra Sense |
| TP-Link Kasa | Smart Plug | Power | 1-2 sec | Intra LAN |
| Home Assistant using TP-Link Kasa protocol | Many | Power | 1-2 sec | Intra LAN |
| Belkin WeMo | Smart Plug | Power | 1-2 sec | Intra LAN |
| Wiser | Smart Plug / Smart Switch / Smart Dimmer | Power | 1 sec | Cloud |
| Philips Hue | Lighting Hub | Estimated Power | 1 sec | Intra LAN |
| Ecobee Historic | Thermostat | HVAC Mode & Runtimes | 5 Min | Cloud |
| Google Nest - Did not pass Beta | Thermostat | HVAC Mode & Runtimes | ?? | Cloud |
| Other Types of Integrations | Type | Data Sent by Sense | Data Source | |
| IFFFT (If This Then That) | Home Control | On/Off Alerts | Cloud | |
| Home Assistant | Home Control | Many | Cloud / Sense Informal API | |
| Alexa | Sense Status | Many | Cloud |
| Type & Integration Name | Caveats & Comments |
| Measurement | |
| NDI (Network Device Identification) | Have only seen this work for a few specific models of Samsung SmartTVs |
| Sense DCM | Works well, but cannot be used if you have Sense Solar - uses the same sensor port / CTs as Sense Solar |
| TP-Link Kasa | Sense must be on the same subnet as the Kasa plugs. Does not work with new Matter plugs like the KP125M or the v2.6 EP25. Practical limit of around 25 outlets due to network congestion |
| Home Assistant using TP-Link Kasa protocol | Not directly supported by Sense. Requires Home Assistant hub and some YAML “programming”. Sense must be on the same subnet as the Home Assistant |
| Belden WeMo | Only discontinued WeMo Insight supported. I don’t have one so I can’t give much more info |
| Wiser | Works but has some issues with standard Sense (orange) monitors - bubbles are a little delayed and Wiser plugs occasionally output 1MW power spikes. Support might be better with Wiser (green) monitors |
| Philips Hue | Sense must be on the same subnet as the Hue Hub (wired). Grouping lights into groups and rooms can potentially cause issues |
| Ecobee Historic | Requires authentication - not sure 2FA with Ecobee works with Sense yet. No realtime feedback that the integration is working, because it mainly supplies data to Sense to improve models over the long term |
| Google Nest - Did not pass Beta | Google completely changed Nest API when Sense was working on integration |
| Other Types of Integrations | |
| IFFFT (If This Then That) | Works, but I haven’t found much use for it - limited number of Applets |
| Home Assistant | Useful for controlling home functions based on power use, but requires Home Assistant hub and “programming” |
| Alexa | Works, and can answer a range of questions |
