How do i change the name of a device that Sense identifies?
New install and finally got some loads identified
However it mistook my spa for my ac that is not even turned on now as it is 50 degrees
How do i re assign this load to the spa ?
Hi @rm10x - you can rename and change the type of devices that Sense identifies through native detection.
For devices that you have identified using integrations (Hue, Smart Plugs) or via Dedicated Circuit Monitoring, you can select the “What’s being monitored” field to select devices that Sense may have detected and prevent duplication.
Is there an advantage to go through and identify the name and model number of a connected appliance or is it just for my personal reference
(Sorry I see this was already asked and answered) But I am sure I will have another nubie question in a day or so
