Hi folks,
Finally got some free time and switched to Unifi routers. Deep Packet inspection shows:
125Mb Down
1.79Gb Up
to Amazon (assuming your server infrastructure is on AWS).
This is from the last 2.5 weeks. Is this expected behaviour?
Hi folks,
125Mb Down
1.79Gb Up
The last 18 days of my Sense from Unifi.
I believe in a thread a while back, the couple hundred was quantified a bit more to around 300Mb / day.
My use from a 10-day period. As you have more devices detected, you’ll have more local processing of signal data (as I understand it), so less data upload is required.
I believe the above period includes at least one device firmware update, too.
@jamieeburgess, in line with what I have seen previously:
Far less than if Sense were uploading every bit of data that it conceivably could sample.
4M samples/sec x 2 Bytes per sample (really 12 or 14 bits) = 8MB/sec
8MB/sec x 3600 sec/hour x 24 hours/day x 30 days/month = 20736 GB/month.
Something to note:
I’ve been monitoring upload/download since getting a couple of Senses and, as you might expect, a Sense with multiple smart plugs and many detected devices will upload significantly more data than a Sense with minimal detected devices (in my case the second Sense is not actually doing any detection since its CTs are clamped to individual device circuits).
Here is what mine does. Interesting to see that 1GB download. I didn’t think SW updates would be that large on this device if that is what it reflects. I should install my UniFi USG to get better derail.
Since 1/15
Side note: Interesting to see that so many people using sense use unifi as well…
Thanks everyone - seems normal.
Does feel a little on the high side though.
Once the model is trained for known devices I’m assuming the upload reduces.
Ha…It never actually gets trained!
Is there no edge compute going on?
I would have assumed once the signature has been processed by the cloud AI models reading the (seemingly vast) amount of data, Sense can push that signature to the device so it can recognize it going forward locally and report if that device is simply on/off (and then not need to send the data for it to the cloud?)
@jamieeburgess,
Per my quick short calculation above, it’s clear that there is a LOT of edge computing and processing going on in the monitor or we would be seeing 3-4 orders of magnitude (1000x -10000x) more of raw monitor data flowing upstream.
I think you are also making a few other assumptions that may not be completely true.
Begs the question: If bulk (edge) memory were cheap (and available), could the modeling optimization speed be orders of magnitude better?
Thought: If truly raw data were available you could go back and re-process it much more effectively.
Of course Sense must have thought about this in depth when designing the system and spec’ing the edge memory. I’m wondering though if a certain number of test-bed systems (with TB of memory) wouldn’t accelerate things? With 8TB of edge memory you could get almost 12 days of data!
The next question is likely: Could you then ingest that data and process it at the edge without also beefing up the Sense itself … probably only in the lab.
Then again, Folding@home reached 146K TeraFLOPS and SETI@home was on over 5 million PCs. These days: Bitcoin. Wouldn’t it be fun to watch your PC power consumption in the Sense PM this time around!
Maybe that wasn’t such a crazy idea @markandcarrie2004 !
Bitwatt? Wattcoin?
Good question. In my mind, it’s all about the “signals” Sense is looking for and what it takes to “tune in” to those signals, while removing noise. I think Sense is really looking for three types of “signals” today:
I agree from a practical standpoint (meaning I should stop here!) but I do ponder the theoretical …
The cloud upload is restricted by processing, bandwidth and, top of the list perhaps, cost. With higher bandwidth, processing and lower cost would Sense have chosen the upload sample rates they chose. Maybe 2X, maybe 10X, 100X?
High frequency data is surely required at some point, as we know, because Sense is ultimately refining models based on the accuracy of detection (eventually via user feedback) and a good proportion of that detection seems to hinge upon the on/off “signals” that are often begging to be looked at … in potentially raw detail (at least to make a match).
So the question becomes: If you don’t have a high sample rate archive to parse and you know you’re getting the detection wrong (missing the on/offs), you can only look to future successes rather than including past failures (analysis thereof). Strength Through Failure!
There are definitely tradeoffs in the current system-level architecture and division of labor, driven by the relative resource (CPU, GPU, memory, bandwidth) costs and availability, but I don’t see a solution, even with vastly improved cost structures that would entail bypassing a DSP front-end filtering and extracting features… Why ? Because RNNs (recurrent neural networks) that are used to make predictions based on time-series data are resource limited, even with the amazing hardware becoming available. The number of parameters and computations needed for a fully connected RNN, blows up quickly with every new time stage - If you wanted to look at a 1/2 second window using incoming 4M sample / sec data, you would have an RNN the size of the Sun (OK, just exaggerating). The good news is that DSPs are kind of a degenerated RNN that is optimized for finding signals in realtime with lots of incoming data.
There are likely a few folks at Sense that look at the raw data and work on refining the DSP front-end to improve feature selection, and to squeeze out more, better features. I also think, based on my back the envelope calculation that Sense does occasionally upload chunks of near raw data for particularly interesting transitions/events. My take is that the better strategy for “Strength through failure” is to continue bringing in good-quality ground truth. That’s where regular fails and wins can have strong influence on the learned identifications. But poor-quality ground truth, or misguided ground truth, can also cause identifications to bounce around.
Precisely.
… and so with sufficient grunt, in theory the DSP “RNN” could be part of the “Sense RNN”.
But yes, I agree, effort at a larger scale (longer samples, post DSP) is no-doubt a more solid and practical strategy.
