I’ve noticed that all of the Sense unit’s application communications appear to be over ipv4 (DNS, HTTPS, and SSL-Syslog) which is all well and good considering the current target environment. I do also run a full ipv6 environment in my home, though, so I was curious if the system is intended to support IPv6?
After checking, sure enough, there was a neighbor known to my router with the MAC address matching the v4 IP. It looks to have been obtained via SLAAC (not dhcpv6, since I have both), so it definitely looks like the device supports dual-stack functionality . What is the state of v6 in the product? Is it turned on, but not being used since many of the AWS EC services are not yet fully dual-stack capable?
Just curious about this, since I’ve given myself an academic goal of eliminating as much v4 and NAT from the home as possible.
Dan
