Notification for Solar Inverter
Is there any way to setup a notification that my solar invertor is not running? My inventor needs to be reset every so often.
I just leave my old iPhone 5 running the Sense app, I can see the comings and goings of the electricity all day long
You can craft one or multiple solar Goals as detailed here:
I suspect that Sense is considering an automatic alert for such situations because it’s one of those emphatic events that lends itself to some additional smarts. Thinking out loud:
  • Correlate solar output with local sunshine and time of day; lower than expected output ==> problem ==> alert.
  • and/or look at solar history when there is a change in generation not having a cloud movement signature or fitting the likely timing/pattern of shading events.
Not exactly disaggregation of the solar signature so much as using similar logic to the Mains analysis. i.e. Sense Labs > Power Analysis ==> Sense Labs > Solar Analysis.
