Creating alert for low/no solar generation
Is there a way to setup an alert so sense will notify me if my solar system is not generating power?
I had an issue recently where my solar system stopped generating power - and I only happened to notice by chance. I’ve tried exploring options in Sense to get a proactive notification in the future when this occurs, but can’t find a way to do so. The closest I can find is setting solar generation goals - but those can only be configured to notify you when you exceed a certain daily generation threshold, I can’t setup a notification for failing to reach a certain daily generation threshold.
Natively I’m not sure, but just throwing this out there. If you have Home Assistant you could do this easily. You might want to do a product suggestion post for that feature since I’m sure it would be trivial to develop.
Make sure you vote for it.
