We’ve had lots of requests to make extension cables for the Sense current sensors available to help support distant solar feeds (like a solar sub-panel that isn’t right next to the main panel) and other needs. We now have those available in four lengths: 4’, 12’, 25’, and 40’ at a special page in our web store: store.sense.com/accessories
You’ll also find replacement parts like antennas, mounting brackets, and power cables should you need them.
It’s been a whle since I’ve installed my Sense, but I found the plastic mounting fitting for mounting the antenna very flimsy. I’d like to see a more robust mount made of metal or hd plastic with threads and a locknut. Similar to this 1/2” cgb, picture attached.
Thanks, David
Very nice to see the longer cables. A couple common sized panel knockout grommets would be nice to include for external installs where you must feed the cables through the enclosure.
I wish Sense offered a wifi antenna extension cable. The short length limits where I can place my unit inside my panel…
I was looking at aftermarket cords, and posted a thread on this board about it… but everyone felt like none of the 3rd party extension cables were safe to be inside an electric panel given that most of them had a metal screw nut…
