That definitely makes sense, but it’s not quite how the integration works. So, we’ll actually make every attempt to not detect a smart plug device via ML after you’ve connected it to a smart plug. This is very much intentional, as we would not want wattage to get duplicated from multiple iterations of the same device or device components. That said, we still collect data for it in the typical fashion and if you remove the device from the smart plug, that data will be used to help with an ML-based detection.
