I did some detailed analysis of my SolarEdge inverter vs. Sense here:
Bottom line is that Sense came in approximately 4% under my inverter for any given day or hour, and Sense was more accurate when looking at comparisons against my revenue grade utility net meter.
So your Sense is probably more accurate. If you have access to .csv’s for your hourly production from your inverter, you should chart a comparison.
