Stacked power plot for Always-on, ID's appliances, and other?
Thanks, very useful!
My only comment is that I would put the less variable ones on the bottom, e.g. always on. And then the most variable ones on top. That way the plot would be easier to read, now it seems that the red is very variable, but it is pretty constant really.
So you (or Sense) could compute the Std Dev of all the points in time for each of them, and calculate the relative std dev (Std Dev / Mean) and stack them with the lowest RSD at the bottom and then by increasing RSD. Except always on probably should always be at the very bottom.
(Not asking what you do this with your plot, though I’d surely be curious to see it if you did … :wink:
