Still no support for multiple sense units?
I’ve been using sense for 5 years now and it’s paid for itself (many times over). I would like to extend the system to better monitor the house. I have a big place, the mains come into the basement and I have my sense unit there… but there’s a subpanel in the garage that services that space, vehicle charging, and has a run out to a panel in a second building (bike garage) that I just installed. That space is 100% electrical (using a mini split for heat) and I REALLY want more accurate data regarding consumption out there. If I could add a second sense unit (sub-unit) I could monitor power in those spaces more accurately. (not getting good discrimination of the mini-split consumption from the app).
Anyone have a circuit monitoring alternative that feeds into the sense app? (I use smart plugs for some appliances but these are not plugged devices).
Don’t get your hopes up. There doesn’t seem to be much development on anything lately.
An alternative that feeds directly into the Sense app is unlikely, as @flipflopkid says. An indirect feed is possible with Home Assistant. I can’t give details because my own efforts to set up Home Assistant were abandoned, or at least left for later. Yet I know enough to say that there is likely a way to make it work if you really want it.
I think the most likely solution is to go with a different vendor… sucks.
