Strange power use in intervals
Having used the Solar CTs for non-standard probing of devices (i.e. not to monitor a solar inverter) I have wondered about the calibration cycle details:
According to the install guide you need a minimum of 150 watts being generated during the calibration cycle. i.e. Startup or a reset (?) at night won’t work.
Would be interested to know what the outcome is here @oasis so please report back what support advises.
I agree with @james_reilley’s suggestion here for the periodic loads … some users think that a device meter will emphatically go on/off when flipping breakers, which is sometimes not the case. In your situation though, looking at the Mains meter, you can easily identify when the periodic load drops. I would suggest also using Settings > Signals for that because then you can ID the phase (leg) the load is on and determine if it’s 120 or 240V.
To expand on @ixu’s suggestion of looking at Settings > Signals to help identify the phase/leg the periodic loads are one, it would be a good for product wishlist item to have have the capability of having the power meter graphs show each phase/leg to aid in such debugging efforts. There already is such a wishlist item that I encourage folks to “like”:
I don’t know what the power profile over time for the actual Sense device itself looks like, but the device @oasis is looking at fits into the the Sense monitor power envelope of less than 5W if you look at it over time (average is 15W * 0.25 = 3.75W).
His/her usage patterns are incredibly simple and well-defined. I can see how it would be very frustrating to see those device patterns and not be able to name them…
The inverters do consume power from the grid when the solar array is not generating. My Enphase system draws 3-4 watts of power at night for the Envoy unit. It’s also connected via a line side tap and not a breaker to my main panel.
There is also a pulsing wattage nominally every 3/seconds of about 3-5 watts that is a mystery as well. I can on,y gets close look at it during the night because the graph will not let me move around to see the top. That should be a wish list items as well; the ability to enlarge the meter display and then move it around together a close look at things. Since I keep seeing the confusion on this point it is “he”. In fact retired he.
I would have swore that you could zoom in like this, but checking myself right now (on iOS app and web) and you are right…the bottom of the graph is always anchored at 0W…it is not possible to zoom in on the power profile itself. Not sure if this is a recent change in functionality, or if I remember erroneously.
Solar inverters DO use power.
During the day they consume from what is being generated from the array.
At night they consume from the grid.
My inverter is consuming 7watts of power from the grid at night.
