Peak Power consumption
It would be nice to get the peak power used for a range of dates. This would allow us to better size our standby generator needs.
It might also be helpful to get this number for daytime peak vs nighttime peak (as specified by hours specified or dynamically by latitude and/or solar production measurements) so we know what our needs are.
And add to this (just to be complete) our daytime effective peak when subtracting out the solar production.
Yes, peak would be great. Seasonal would be nice for heating season vs cooling season. I bought our Sense specifically to help with generator sizing.
One other thing. The peaks should be able to show the peaks for each of the 2 phases of power. This would allow better balancing of each phase for 240v generators, batteries etc. There may be other benefits as well.
Please consider adding something like an Avg Startup Peak to the device stats page to show the inrush current of a hard starting device. There is an example attached. This is helpful for those of us using the Sense for generator planning or power conservation during a power outage when running on generator.
Thank you for the consideration.
Has there been any update on this? I’m facing the same issue, we need to size a generator. The installer may need to come out and put transducers into my panels to measure peak power usage in the last 30 days to prove to the electrical inspector that the generator is large enough. I would think that Sense could give me the information right now, but I can’t find a good way to export the data.
@arlomiller,
If you are looking for max instantaneous power, two steps:
  1. Set the Power Meter to Month
  1. Zoom in on the highest peak and measure it using the measurement bar.
Load balancing needs to be considered. Currently there is no way to see what loads are on each line and what loads are on both lines.
