Yes, only backend usage for the data science team at Sense. But it seems to have improved Sense detection of my 2 HVAC units. Long history here.
Thanks for the patience here, everyone. The Ecobee integration should now be working if 2FA is (or is not) enabled.
If you are still experiencing issues, clear your cache and delete the integration before attempting set-up again. If you’re still unable to enable the Ecobee integration, please reach out to our Support team (support@sense.com).
Confirmed, with 2FA enabled. Thank you!
Confirming that’s its working without 2FA
Working for me, without 2FA
What is the MFA, you mention here?
Per Ecobee’s documentation they only use 2FA. The terms MFA and 2FA are often times interchanged. MFA however, involves introducing more factors of authentication to the process of authentication. 2FA is a subset of MFA that involves using exactly two factors of authentication.
