My home has 2-200 amp electrical panels feed from the electrical meter. I’m now adding solar panels. Is there a monitor that can handle all 3?
There is not a direct 3 CT pair solution today. But I have the same thing as you - 2x200A busses coming out of my meter, with solar. My Sense main CTs are on the incoming pre-meter cables, with the solar/flex CTs on my solar feed-in breaker. Works just fine even though I do use up to 110A at times.
ps: going to move this into its own posting.
