Daily Temperature display on Sense
I image that for many people (maybe not all) that the outside temperature greatly affects our consumption of electricity. Whether that be solar production, heating, cooling, hot tub, pool, etc, the weather can play a large role in how much energy our homes consume. I would love a feature that shows the average, high and low temps for each day when looking at “trends”.
I actually have two heating systems that I can chose from, oil furnace or ducted heat pump. It may sound like a no brainer to use the heat pump, but when the weather gets below 10F, I feel like my oil furnace is more efficient. (This is the primary reason I bought the Sense, to discover this truth).
So, in short, I think it would provide some good insight to understand how much energy our homes consume/make compared to the outside weather.
Anyone else agree/disagree?
Agree my utility shows temperature. It would be nice to see it on Sense
I have a slightly different perspective since most of my heat comes via natural gas, though I recently added some electric floor heaters… I think the thermostat is the natural place to correlate energy usage (or at least heating/cooling runtime) with temperature. But I already get that out of my Ecobees.
Just wish the floor heating thermostats had as much smart as the Ecobees - the proprietary NuHeat thermostats cost about the same, but only give this, without any outside temperature info.
+1 on that.
I understand that is a “trivial” feature in the scope of what sense is working on, but is very nice to see, and would be great to see in sense directly since I barely even look at the utility site since installing.
Here is how my utility shows it.
I wish my Nest thermostats displayed the temperature like that. It sure would be helpful.
That is a great way to represent the temperature in relation to energy used. Thanks for the great example.
gatchek…[quote=“gatchek, post:1, topic:9625”]
[/quote]
I really think what you are looking for is the heating and cooling degree days. This is computed on the ave high and ave low of the day. " A heating degree day (HDD) is a measurement designed to quantify the demand for energy needed to heat a building. It is the number of degrees that a day’s average temperature is below 65o Fahrenheit (18o Celsius), which is the temperature below which buildings need to be heated." Then there is a cooling degree day…
Here is a report from my area on the weather for the month. It has the heating degree day in the middle… Some NOAA radio stations broadcast this information. If this is what you are looking for I will go into more detail at a later time…Enjoy…Gerry
MONTHLY CLIMATOLOGICAL SUMMARY for JAN. 2020
NAME: xxxxx CITY: Luzerne STATE: Michigan
ELEV: 1140 ft LAT: 44° xx’ xx" N LONG: 84° xx’ xx" W
               TEMPERATURE (°F), RAIN  (in), WIND SPEED (mph)
                                  HEAT  COOL        AVG
MEAN                              DEG   DEG         WIND                 DOM
DAY TEMP HIGH TIME LOW TIME DAYS DAYS RAIN SPEED HIGH TIME DIR
1 26.4 32.2 3:30p 20.5 8:45a 38.6 0.0 0.02 7.9 26.0 5:45a W
2 36.2 42.1 2:30p 30.9 3:00a 28.8 0.0 0.26 8.6 25.0 3:45p SW
3 33.0 37.6 12:15a 29.3 11:45p 32.0 0.0 0.00 3.8 20.0 2:15a W
4 27.2 29.5 12:15a 25.2 8:45a 37.8 0.0 0.00 4.4 17.0 2:45p W
5 27.4 29.4 12:00m 25.8 12:45a 37.6 0.0 0.00 6.3 23.0 9:45p W
6 27.8 31.0 1:30p 24.7 12:00m 37.2 0.0 0.00 11.1 37.0 2:00p W
7 28.6 36.0 12:00p 20.7 12:00m 36.4 0.0 0.01 8.5 28.0 12:00p SW
8 15.3 20.7 12:15a 8.8 12:00m 49.7 0.0 0.00 6.4 30.0 11:15a WNW
9 23.4 40.9 12:00m 8.8 12:15a 41.6 0.0 0.02 9.5 28.0 10:00a SE
10 39.0 44.8 4:00a 32.0 7:30p 26.0 0.0 0.00 6.0 23.0 4:00a SW
11 24.3 32.5 12:15a 13.7 12:00m 40.7 0.0 0.14 8.2 25.0 5:15p NNE
12 14.8 18.0 2:30p 9.5 8:45a 50.2 0.0 0.00 3.3 23.0 12:30a E
13 24.0 29.2 4:15p 17.5 12:15a 41.0 0.0 0.01 0.7 9.0 2:30a ENE
14 30.2 32.4 7:00p 27.0 1:30a 34.8 0.0 0.01 2.8 16.0 9:00p SW
15 31.0 33.3 1:45p 28.3 12:00m 34.0 0.0 0.01 3.2 15.0 2:30a WSW
16 22.3 28.3 12:15a 15.3 8:15p 42.7 0.0 0.00 6.6 27.0 1:30p WNW
17 17.0 19.9 2:45p 14.3 8:30a 48.0 0.0 0.01 4.2 17.0 11:15p ESE
18 24.8 29.7 3:15p 18.7 12:30a 40.2 0.0 0.00 9.1 26.0 9:00a ESE
19 16.2 26.8 12:15a 7.1 11:45p 48.8 0.0 0.00 4.3 18.0 11:45a WNW
20 11.3 22.1 2:00p -4.3 8:45a 53.7 0.0 0.00 2.7 15.0 2:45p W
21 21.7 28.6 4:15p 12.3 8:15a 43.3 0.0 0.00 7.9 23.0 11:00a SW
22 27.8 36.5 3:00p 23.3 2:45a 37.2 0.0 0.00 8.1 23.0 4:00a SW
23 28.9 34.0 4:30p 25.4 7:45a 36.1 0.0 0.00 3.5 13.0 4:00a E
24 32.6 36.7 12:45p 30.9 12:15a 32.4 0.0 0.01 8.3 25.0 1:30p E
25 33.5 35.6 1:45p 32.5 7:00a 31.5 0.0 0.18 2.5 10.0 11:00p W
26 31.5 33.2 2:45p 29.1 10:30p 33.5 0.0 0.02 7.8 23.0 1:30p W
27 29.0 29.6 1:00a 28.0 9:15a 15.8 0.0 0.00 5.1 17.0 1:30a NW
28
29
30
31
26.1  44.8    10    -4.3    20  1029.6   0.0  0.70   6.0  37.0     6       W
Max >= 90.0: 0
Max <= 32.0: 13
Min <= 32.0: 26
Min <= 0.0: 1
Max Rain: 0.26 ON 01/02/20
Days of Rain: 6 (>.01 in) 3 (>.1 in) 0 (>1 in)
Heat Base: 65.0 Cool Base: 65.0 Method: Integration
The editor did something to my data… Try this… Sorry…Gerry
                                  HEAT
MEAN                              DEG
16 22.3 28.3 12:15a 15.3 8:15p 42.0
28
29
30
31
Yes, that data looks very useful, and it easily available. I had never heard of a heating degree day, so thank you for the education.
Re-read this blog in the SENSE forum. You will see several people have tried to correlate outside temperature to home energy use. There is a slight correlation, but mainly your electrical usage depends on many other factors. Use the CDD or HDD data/charts and plot your own graphs in EXCEL. I don’t think this is something that we should ask the SENSE programmers to provide on the SENSE app.
I am new to Sense so bear with me. Is it possible to export CSV file of power usage at various intervals from Sense? i.e. 10 minutes intervals.
Yes - you can export up to a year’s worth of data at a time via the export icon in the upper right corner of the web app, though only in either 1 day or 1 hour intervals. Very useful. I think right now, all reporting in Sense, as well as the underlying data structures except for the various Power Meters, is aggregated into 1 hour values.
They seem to be in milder climates. Would be more of a correlation further north especially if you are on electric baseboard heat like me.
I would imagine that depending on where you live and what type of heating/cooling system you have, the outside temperature Can play a significant role in electric usage. I can’t speak for anyone else, but in New Hampshire, with an air source heat pump, the winter weather accounts for 75-80% of my electric usage. (I originally bought Sense to have a greater understanding of this actual %).
So while the weather may not play a significant role if you live in a mild climate with a natural gas heating system and a brand new energy efficient home, the weather does play a large role if you live in more harsh climate, with poorer insulation, and an electric heating system.
While I completely agree that outside temperature is not everything, obviously daily living variables account for usage as well, but for some it most certainly has a large impact. For me (eastern Pennsylvania) it most absolutely does, and is backed by the screenshot I posted earlier. As you can see, there is a clear correlation between temperature and electric usage for me. I would assume that is why my utility company provides that graph in the first place. I as well have an air source heatpump with electric strip backup. When the temperature drops below 20ish degrees (F) the heatpump is essentially ineffective and runs constantly and the backup heat strips cycle on and off as needed to help. My backup heat is 15KW alone so as you can expect, it adds up very quickly.
I have included 2 more months back after my previous post to show this is not just a fluke in the data:
In addition to integrating daily temperature data from public sources I would like to see integration with a temperature sensor located at my house. This can provide more detailed and accurate temperature of the housing site. Local conditions such as leaves on the big tree out front will be included. Support for multiple temperature sensors indoors and out would be helpful. These can also help to assess HVAC efficiency and effectiveness.
