Given you are still relatively early in your Sense experience, I would recommend waiting a bit since your are going to have a bunch of new detections and a better view of what Sense might be missing after a few months. My advice is to get a KP115 first to use a roamer or traveller. Connect it to Sense by turning on the integration, then plug it in to each device you might want to monitor for a couple day. Sense will give you the history for that period, plus the Always On for that device. Sense has a limit of about 20 smartplugs where an HS300 counts as 6, even if some of the plugs are unused, so the roamer measurements will help you use smartplugs more judiciously with Sense (don’t bother with a cluster of devices that aways add up to between 40 and 60W (my networking closet - I wasted an entire HS300 on that). More wisdom in the thread below.
