My firewall blocks outbound connections by default, so after installing the monitor I checked the logs to make sure that no connections were being dropped. I noticed that the monitor was trying to connect outbound on TCP port 6514, so I opened this up.
I know that most people don’t block outbound connections, but if this port is used you might want to add a mention of it to the documentation.
