Not sure what to tell you. I’m on HA Core-2021.11.2, and have been there for a bit. I didn’t encounter a change when I did upgrade, but I have solar. Here’s how mine is wired up in the Energy Config - to Daily numbers.
True that I’m aware of it, but I don’t know why you have an issue and Kevin and I do not. I do not have return to grid but I do have a generator. So the commonality that Kevin and I share is that we have the daily production populated. There’s no reason why you shouldn’t be able to populate daily production as well. Since it will be 0 there should be no negative effect.
Also, it should be noted that we are using an unofficial method of obtaining this data from Sense and the issue is completely third party related.
@kevin1 can you check the energy usage and hover over the bar on the furthest left to see the time that you have for that reporting. I’m not getting any reporting from 12-1am and it looks like you aren’t either by your screen shots. Just want to confirm.
I think there’s a bug with HA and daylight savings where 12-1am = 1-2am and so on. Everything is 1 hour forward.
I’m traveling right now and don’t have HA enabled for remote. Won’t be able to snap another shot until Sunday. Sorry. I did wonder about DST when I saw the issue.
And I know why it is happening. Not a a DST issue. If I look at the underlying HA data via a query, it becomes obvious. HA is using the DAILY from grid, to grid and net production. Unfortunately, the HA Sense integration only produces only 1 value per hour representing the energy usage over the previous hour, EXCEPT for midnight / 12am. There, the HA integration zeros the midnight reading to start the new day. What we really need is the HA integration to produce that last value for the day and subsequent apps need to assume zero is the starting point for the new day.
Also the bad data in the 12am started right after the 2021.11.2 core update as I originally stated up top. Yes, it’s replacing no data with bad data, but it’s screwed the rest of the day for me as well.
Until the underlying problem is fixed, I’ve used the Yearly values in the HA Energy configuration and that made everything work. All hourly, daily values are now spot on and no midnightish shenanigans. I’m guessing that once a year, it will mess up but for now (or until a fix), I’ll take that.
@Beachcomber, you might want to try to query your HA database for those two entity values to see what’s lurking in there. But that would either require an SQL app or the InfluxDb plugin to reveal. All of my HA energy waveforms going back to Sept 7, when I first configured in the daily energies are 0 for that first hour - no big negative hours.
@jeffml,
I finally figured out the full issue here. Home Assistant energy module expects the typical dumbest output of a smart meter which is a single, or multiple, cumulative energy usage / production data stream vs. time that monotonically increases forever. Sense integration doesn’t do the forever thing. The best it does is a year, as you suggested.
