How can I see my all-time peak load?
Is there a way to see what my all-time peak load has been?
If you have Notifications turned on for New Peak, you’ll get updates every time you hit a new peak, even a spike. But that only works for forward-going peaks.
If you want to look retrospectively, I would suggest you go into the web app and do the following.
Type a link in the URL like the one below, with the first day your Sense went into service for your ‘start’ and the current date in YYYY-MM-DD format for your ‘end’
https://home.sense.com/meter?start=2019-04-10&end=2020-08-10
You’ll get a Power Meter view of your entire Sense dataset.
From that, you can zoom in on the biggest spike and measure.
Thanks - worked like a champ!
