Recently I heard my A/C condensing unit cycling rapidly. I went to the thermostat and it was quick cycling the cooling. Resetting the t’stat and a battery change did not solve the problem. Installed an old t’stat as a temporary solution. A check of Sense
As you can see the cycling was pretty rapid. And as the following shows the t’stat had done it earlier but i didn’t catch it.
Here’s my thought: In the future when an item cycles this frequently the system could identify it as a potential issue and an alert can be sent. If this had gone on too long it would have been catastrophic.
