I am still using my sense app on a daily basis and still use it to try and figure out what is using too much power and what is working efficiently and it really helps me to know when I need to get my split type air conditioners cleaned and serviced which seems to be about every six months since I live in the Philippines and its always hot here and I use the air conditioning every day. I use cielo breez max smart thermostats to control my mini split air conditioners and it tracks the temperatures of each room that I have them in so I can try and keep the house at the same temp and was thinking it would be nice to have a graph that showed the outdoor temperature with the power usage to show how it effects my power usage.
To: @mike_gessner There is an old forum thread from 2018 discussing this issue. See my post:
I live in south Texas (where it is usually always hot and humid) and had the same thoughts that you posted. After running my correlation calculations, I proved that my energy use is only very slightly correlated to outside temperature. Read my full post and all the other posts in this thread if you want to gain more information.
