Is my meter failing?
Noted on Aug 29th that my usage started trending upwards and found that the meter is recording errant usage as solar comes online.
As Sense real time meter shows solar production increasing,the power usage starts to increase in parallel fashion. I’ve posted power meter history here.
Has anyone run into this? Have not reset anything atm…will try shortly.
Will
5KW PV system
200A Main
2 100A Subpanels
(1 for main home and one for guest home)
Sense is in main home sub-panel with solar circuit
Check here:
You should probably start by contacting Support but you could detail your configuration (where the main and solar CTs are) here if you suspect something might have changed (physically) since the erroneous metering started.
