How do you tell when your KP115’s disconnect? I’ve had mine (7×) for 4+ weeks and never had an issue. Is there a trigger one can set up for when the plugs disconnect or you go back to your data and examine all of it ‘manually’ ?
If you explain how you get notified when yours disconnect, maybe we can all monitor ours the same way and assess how wide-spread the issue is.
Probably worth reading through this thread. Gives a lot of info on how the Sense monitor communicates with the smart plugs, including some information from Jonah, the Sense Monitor firmware guy.
More on Jonah, plus some insights on what happens within the monitor here.
I set a custom alert to notify me when the refrigerator is off for 45 minutes. It always cycles on and off all day, but I normally don’t see it off for that length of time. When Sense loses sight of it the alert will trigger. When I get the refrigerator alert 1) I confirm it is running, 2) I look in Sense and can see that all my KP115’s are “not available”.
If you have any device plugged into a KP115 with a reliable standby power draw, you could set an alert for that device.
If you haven’t already, it is definitely worth writing to Support (support@sense.com) to alert them of the issue you’re having. I haven’t seen more than one or two reports of this as of yet, but I’ll be keeping an eye on if this starts impacting more users.
In the meantime, it would be helpful to share this bug/issue with the Support team so they can track how widespread the impact is or see if they are able to isolate a cause of the issue.
I reported it to them Saturday when it happened for the first time. Today I replied to their response to add the latest events and what I’ve done (cycling Sense power, cycling one KP115 but not the others).
I now have straight 6 days of KP115 operation without them vanishing from Sense. The plugs have been solid since the minute the firmware* in my Deco routers was updated (TP-Link Deco M9 Plus mesh routers). TP-Link support gave me beta firmware to fix a separate issue: one of two HS300 power strips would not ‘add’ in the Deco app.
At the moment, I have 2 HS300 power strips, one is behind the TV less than 3 feet from the router, the other is in the garage 25 ft away. I have 3 KP115 plugs, one behind the refrigerator (~15 feet from the router), two are in the garage (35 and 45 feet and several walls away). All five of these monitoring devices are showing now in Sense for the last 6 days (the HS300s never had any issue).
Off track, but I counted wifi devices in my garage and found that I have 16 there: 2 wall switches, the Sense, Rainbird lawn irrigation system, HS300 6 plug power strip, HS105 plug, HS107 dual plugs, 2 x KP115 plugs, MyQ garage door opener. The KP115s were the only devices to have issue with Sense, and none have trouble with wifi connections or the Kasa, MyQ or Rainbird apps.
*The issue with the HS300 not adding in the Deco app was due to the firmware having a limit to the number of plugs (32) they could accept. The Kasa app had no such limit and allowed all the plugs and power strips to be added and configured.
