kWh Real Time Dispay
Hi,
I just purchased an additional set of current transformers for my Sense that I will use on my EV charger. I want to be able to see the energy (kWh) accumulate in real time. Will that be possible?
I am hoping to be able to see a live value increase as energy flows into my car. (0.00 → 0.01 → 0.02, etc.).
I did do a quick search for an answer but no luck. Maybe once the sensors are installed the answer will be obvious, but appreciate any feedback now.
Thanks in advance
Good question. Unfortunately, the only “accumulate mode” display is the top level Dashboard and that only shows Total Usage for your assigned billing period. The best you can do is add the EV Charger device hourly bars as they are updated each hour.
