Really surprised. Replaced my basement 4’ 4 bulb T12 fixtures (160w) with some new Metallux 2x4 LED Troffers from Home Depot. Have 3 of them wired on the same switch. They were found in under 2 weeks and have been 100% accurate in detections on/off. If you have troffers and you want to replace them, I highly recommend these as a “Works with Sense” . Frankly they should put that on the packaging…
As a side note, the lumens are rated at 4700, which is lower than the 4 T12 4’ bulbs, but lumens go down as bulbs age. We replaced these bulbs a year ago, and the LEDs are just as bright. Installation is easier as these fixtures are as thick as a ceiling tile. They also have tabs if you want to suspend them from a ceiling (like in a shop) as opposed to dropping them in the ceiling tile grid.
